lots of noise....
dolph2000
Hi,
While this subject is already discussed a couple of days ago I couldn't really found an answer what the reason is for the noise in the dark areas except for avoiding noise through 85 b filter adjustments. (Indeed not much visible on computer monitor, but seen on production monitor it looks quite noisy.)
I am in a project shot on dvx 30 p. I have the master ped. -3 and gamma low.(gain 0)
Is this typical for dvx? or wrong adjusments?
thanks
With the master ped set at only -3 you are still going to have a little lightness to your blacks, which will indeed show more noise. By switching your master ped to about -5 or -6, true black is reached and will also help to mask some of that noise.
