Lost my keyframe bar in Apple Color
yoclay
Classic Apple Color problem. I have lost my keyframing bar. Apparently, it has slipped too far under the little yellow line at the bottom of the app. I can't pull it up with the other bars (or the tiny grey rectangle on those bars). I know it's down there and working because the keyframing is still active on the image and there is a little arrow pointing downwards above this yellow line, but - impossible to pull it back up. Anyone know how to reset this?
Digital Rebellion's free Preference Manager will trash your Color prefs, that may help. How did you do that? I tried to replicate it and can't. What Mac/Monitor are you using, what is the resolution of your monitor? Did you try resizing the grades track to it's smallest?
I just simply pulled the keyframe bar too low, it went under the yellow bar at the bottom and never came back. I have tried resetting the preferences in setup and H, M,S, and Frames. No good. The keyframes are still working though. The only workaround I have found is to save the overall grades, pull up an old timeline, copy in and continue there, save those grades when I am finished and come back to the original timeline and drop the new grade in. I have 250 edits on this project, but luckily near enough to the end that it is doable, but a pain.
it's definitely a bug, but as we all know Apple won't be fixing this in any kind of upgrade anymore.
The only other reference I found to this was here, but no solution that works for me:
http://www.coloruser.net/forums/4/topics/325
