Had my gh4 rented for a couple of days. Sadly I noticed when it was returned to me the plastic cover over the flash port/Connector was missing. Where can I buy this ? Does anybody know the correct part name or number?
When I posted this, for some reason I didn't see the pictures and I assumed you meant the hotshoe cover, not the little flash cover. My bad!I think any hotshoe cover will do, though I haven't tried others. Just FYI I found that the same hotshoe cover for the GH4 also fits my GH2.
@blazer003 I included the pics after your postWhen I posted this, for some reason I didn't see the pictures and I assumed you meant the hotshoe cover, not the little flash cover. My bad!
Thanks for the tip !Richie: That terminal is a PC synch terminal, the connector that plugs into it is called a PC connector. They started dropping this from several DSLRs starting around 2004. But I found this on amazon, hope it helps you.
http://www.amazon.com/DSLRKIT-Flash...8-2&keywords=Flash+PC+Sync+Terminal+Cap+Cover
Although it says it's for Nikon cameras, this terminal used to be pretty standard so this should fit our GH4's. If you're likely to take your GH4 with a weather sealed lens out in rain, you should cover this terminal to keep moisture out.
