Marshall Harrington
I'm looking for a recommendation for a custom cable maker.
It's for a set of lights I have where the cables were either not as long as I'd like and the quality was low. I need AC cables as well as the cables that connects the ballast to the fixture itself to be made up. The latter is tricky. Not only does it need to provide the power it also needs to send the color information as well. Apparently there needs to be additional insulation carefully added to keep certain wires separated so 'chatter' is prevented. Also need the Weipu connectors to be tracked down.
If you have any suggestions for a cable maker who's up for this I'd appreciate the referral. Thanks.
