looking for audio/mic solution.
magoo
Hi folks,
My first post here! :) I have a DVX100 ('E' - Europeal PAL version of 'A' i think).
I will be shooting weddings primarily (events also eventually).
First job with this camera in 3 weeks.
My camera is standard; no booms, extra mics, socks etc.
What mic equipment works well with this camera (XLR inputs)?
I am told I should get some wireless mics.
- Do these plug into the XLR input and which input is best (1 or 2).
- Is input 1&2 actually left and right of stereo or 2 x stereo inputs?
-Do I wear a transducer pack or best to strap it at the tripod?
-What is a good thrifty product and where do I get it?
I saw someone elses DVX100 and it had a bracket out the handle side with a directional mic and sock on it. I did an outside wedding last year and the wind was a real pain.
- Is this worth getting also
How would the micing work if I had all of the above working together - or wont it work together.
- Do I get a mixed soundtrack from Input 1 and 2 in any mix of onboard and XLR inputs dependant on switches? So what I mean is ... can I use the the switches in any combination and source; sounddesk cable, wireless, directional mic and expect both inputs to mix onto the DV tape
- ... and will the NLE software (pinnacle 12) pick it all up as I see in Pinnacle only one audio track from the DV source.
Whew! I think thats a decent start. Lots of questions but generally you get the gist!
Look forward to hearing from you.
Magoo
you should look into the audio forum. Lots of great info over there. Quick answer is that different situations call for different microphones. Best to start with what you need the most and buy accordingly as you progress. Good luck
Hi folks,
.... Whew! I think thats a decent start. Lots of questions but generally you get the gist!
Magoo
Think I overcooked the questions.:shocked:
Am shooting an indoor wedding - have access to sound desk - so Audio is probably going to be OK
- BUT - was mostly interested in wireless gear and best method to stop wind noise in built in mic.
Any suggestons?
Magoo
