looking for a part...
infurno
I'm building a camera crane, trying to find a part to connect sections.
Anybody know what its called or where I can find it?
Bore should be 1/2 inch or so big.
I tried Grainger and Mcmaster-carr but no luck so far. It would help if I knew what it was called.
Would appreciate any hints at all.
"pillow block" is usually the word used when it's a strip, not a full square.
Thanks for the tip! All the ones I have found are designed for bearings, but thats ok I can just run a bolt through it instead as planned... However, they are a bit slim. I don't think they would be able to support the weight without bending the metal they would be mounted to.
I may have to just weld tube pipe to the sections instead and run a bolt through that. I was trying to avoid this because im not confident enough of my welding skills. Will have to find someone to do it for me.
