hi, i did this video on tuesday.
http://www.youtube.com/watch?v=kGt1x_lMqzU&fmt=22
i work with my dvx100b
this is what i did:
1.- squezze mode
2.- 24pA (or the little circle in F6)
3.- shutter at 1/48
4.- lightment equipment are two Smith Victor lights (600w)
5.- capture the material using a mini dv camera sony very cheap via firewire.
(i work on final cut pro 2 , academy version)
6. i did this before capture
wento to easy setup
format: all formats rates: all rates
Use: dv-ntsc 24p (23.98) advance (2:3:3:2) removal
create a new sequence and check it was 23.98 fps
7.- capture the material
8.- start editing normal way, use g films filters
9.- to export it, i did this
goto export using quicktime conversion, then Options , Settings, Data Rate (i wrote 4.000.000 but when you click the ok button it will change to 2.xxx.xxx, so do the same and click ok)
then Dimensions, 1280x720 HD, click ok...use you clip name and save
Watch it at 50% size on your quicktime and it will look like this.
hope it helps a lot of people
ask anything you want to know....im not an expert but i have knowlegde
excuse my english
this is what i did:
1.- squezze mode
3.- shutter at 1/48
wento to easy setup
excuse my english
