Joshua Milligan
Ok, so here's a problem that's very real for me that I can't seem to find a good solution for. I film a lot of wildlife related content and have worked in various remote parts of the world filming different species over the last several years. My weapon of choice is the Sony FS7II (was the FS7 before that) and I also have and use an A7RIII and A7SII.
This January I made the switch from Canon L glass to Sony GM glass so I could finally ditch adapters and so that I could have usable autofocus in video (and better AF in stills) with my two mirrorless cameras. Autofocus on the A7RIII is very helpful for me when shooting things like two cameras interviews by myself when I'm behind the FS7II and need the A7RIII to maintain focus on its own for me. It works very well and has absolutely been worth the switch.
The downside to switching was that I knew manual focus was going to be much harder and that I would have to give up my Canon 18-80 Cine Servo lens. I was ok with this, however, as the Sony 18-110 is a good lens in of itself and manually focusing with the focus-by-wire lenses was something I could learn to do over time. What I didn't expect to lose, however, was usable IS (or OSS as some call it) in video.
When using my FS7II, and quite frankly even the A7RIII and A7SII for that matter, the IS on the 70-200 GM and 100-400 GM is basically non-existent. I know that the world says to not use IS when shooting video on a tripod, but the reality is that without IS when using long lenses, I always end up with shakes is my footage. Whenever I touch the lenses, even gently, to pull focus, or when I make adjustments on the camera, everything shows up in the shots. When I was using the Canon 70-200 L II and 100-400 L II, I didn't have those issues. The IS in those lenses was so good that none of that showed up. Everything was smooth and looked rock solid, allowing me to have great looking results in post.
Now with the GM lenses, the IS on them doesn't activate or work at all unless you shake the camera around a lot to "wake it up". Obviously you can't do this when filming and even if you did, it only stays on for a handful of seconds before it falls back to sleep. My Canon lenses weren't like this. They were always on and always actively working to stabilize my shots. I understand that people are afraid of the drift that comes from stabilized lenses, but honestly, it never happened much to me and even if it did, I would much rather have that than the shakiness I have now. Because of the shakes I get, I'm constantly having to use Warp Stabilizer in post to fix my shots, which doesn't always work too well, and even when it does, it slows down my workflow tremendously.
So now I'm at a crossroads and I'm not sure what to do. I'm all in on Sony at this point and do love their lenses for autofocus in photos and video when needed. I also love not having to use adapters anymore. But this IS issue is killing me. I can't afford the money it would cost me to switch back to Canon, nor do I want to lose native lens functionality, so I'm not sure what to do. I have been hoping that Sony would release a firmware update for the lenses that would let them stay active all the time, especially since others out there have also found this problem, but that hasn't happened yet. So what should I do? Also, I do have a great tripod. I'm using Sachtler sticks with a Sachtler FSB-8 head which is a very nice combo, so I'm not blaming that.
Do any of you, like Doug who I know films wildlife, have any advice on how to combat the shakiness in long lens filming? I would much appreciate it. Thank you!
