[FS: General] LOMO anamorphic Zoom lens F = 25 - 80 /3, T = 3.4 , PL mount
Sergey Kravchenco
Up for sale NEW not used earlier - LOMO anamorphic Zoom lens F = 25 - 80 /3, T = 3.4 and afer mounting rear anamorphic adapter - you will have anamorphic zoom F = 50 - 160 , T = 5 . Lens not used earlier .Lens converted on PL mount and mounted ARRI standard focus and zoom gear rings .Glass is fine , multicoating not damage . Ser N 880001 .Lens cover format 35 mm - 4K for RED One camera .It is one of the best compact Zoom lenses extra sharpest and very contrast .Light weight - need not support - weight only 1.3 Kg ..It is possible to use zoom lens without rear anamorphic adapter ( PL mount attach ) , in this case Zoom lens will has F = 25 - 80 / 3.4 - you must replace anamorphic adapter and to fit gasket ( including in set ) for normal non anamorphic lens - need not collimate after it .During 5 minutes you can has normal zoom non anamorphic with F = 25-80 / 3 . In set hood and two front diopters lens 0.4 and 0.6 - see on photos .Lens comes in original case
Technical date for anamorphic zoom :
F = 50 - 160
T = 5.0
Normal zoom ( not anamorphic ) :
F = 25-80/3
T = 3.4
Close focus - 1M
Length - 180 mm
Weight - 1.3 Kg
Visual resolving power = 100 1/mm lines in center
Focus scale engraving in meters .Lens has front and rear caps
Below you can find some photos of this lens .
If you will buy zoom lens without rear anamorphic adapter , then price of zoom lens
F = 25 - 80/3 - $ 3000
If you wish to buy Zoom lens with rear anamorphic adapter ,
then price of anamorphic zoom lens
F = 50 - 160 , T= 5 will be - $ 4000 - SOLD !!
Lens very compact and light weight - NEED not support !!
If you have any question or additional information - please contact with me :
sergastr@list.ru
sergastr@yahoo.com
Best regards
Sergey Kravchenco
Canon 7D with Zoom OPF29
