Live projection
matt s.
What is the best possible way to project the 150 live? I do know the projectors are HD with HDMI but I'm pretty sure I'm going to need a long cable run to the system. Basically will be covering MMA fights to be projected onto screen. Any help would be appreciated. I've never done this before and assume it is possible just dont know much about it.
I second the HDMI over CAT-5. I know an engineer who wired a BPix rack to control room monitors using HDMI over ethernet.
If the projector has HDMI in you can use an HDMI repeater that will give you the extra distance. Though HDMI cable isnt cheap compared to the above mentioned route if the infrastructure is already there.
