SOLD LitePanels Mini LED single light kit
Status
Not open for further replies.
The light pictured appears to be the older Mini, not the current MiniPlus. This is evidenced by the filters attaching to the front with velcro as opposed to fitting into metal holders. (There are other differences between the two versions.)
I do have a shoe adapter. I also have a noga arm if it's necessary for the sale, but currently it's not included.
I guess it is the mini minus plus then....(anyway to edit the title?) I actually have two litepanels mini's and the other one has the metal filter holders. After years of use I couldn't tell any differences between the two, but I never read a litepanels spec sheet. Care to elaborate on the differences maplecap?
POH I've sent you an PM.
MiniPlus changes: Metal filter retainers on front replace velcro filter mounting (though the metal parts are available as a retrofit option), upgraded electronics and higher light output, jack for remote dimmer operation, onboard dimmer dial includes off position.
Status
