Lilliput Monitor has Died
Andy Turner
My Lilliput monitor has died. It will not display any video from a camera and I cannot access menus. It powers up and I get a blue screen for a second or two and then nothing but the red power light.
Anyone else have this problem? I only used it a few times.
Mine does that when there's no video input. It powers up, doesn't sense any video input then turns itself off. Can you verify you're sending it a signal? also, the red light means it's out of battery, so plug it into the ac charger and try. Unless it is already, that is.
what they said. The monitor isn't getting signal if you're getting a blue screen. It's normal behavior for it to shut down without a source signal. If nothing has changed in terms of what you're trying to send to the monitor, go to the lowest common denominator; the cable.
In my experience, 99% of problems like this ( sudden loss of conectivity) winds up being a failed connector or bad cable. Start simple
