I'm a big fan of the "SmallRig Drop-In Baseplate (Manfrotto 501PL QR Plate Compatible) 2006".
Manfrotto plates are used all over the p[lace including on a Ronin S or the Small Rig VCT-14 shoulder pad so its easy to shift the camera to different support choices without changing the basic plate . Get a long base plate and you have a lot of room to adjust balance. Very flexible.
2 caveats - Different manufacturers make Manfrotto plates that are slightly different and require slightly different adjustments in the base plate. . I had to experiment around to get one that worked with all my stuff. also Watch out for the screw that tightens the lock, I use lock tight on it.
