j1clark@ucsd.edu
oh what a great reply, thanks..
yea i think i managed to understand how to deal with the daylights.
i'de also like to hear your advice on the evening living-room test problem please..
the help of the 800w can solve most of the underexposure, but how to correctly place it to minimize fake shadows?
i will try Ronald's tip on the subject (spotting to one surface and not corner ceiling above lampshade), but it's far from perfect, and still limits me from any actor movements.
you could see the room sketch and jpegs in previous replies.
only if you have time, of course![]()
Since I don't know the exact conditions of your test shot, I took the liberty of cleaning it up a bit. I used simple Photoshop 'curves' and eye droper on the presumably white strips on the shirt, to clean up the 'whites'. Then I used levels to adjust for 'brightness'.
The result is 1) I don't see the shadows you are concerned about, 2) the biggest thing for me is the 'hot' light in the corner. That sort of moves the eye out from the central figure on the couch.
This may be where a 'dimmer' would be in order, or, some form of neutral density material to knock the light down from the practical.
Do you have a light meter so you could indicate what the reading was for this setup.
In terms of 'mood', if the mood goal is 'down/depressing', the brightness on the left side seems too bright. This may be just a consequence of pointing your 800 W into the corner and letting the light go where it may. Perhaps some sort of rig where you can screen the light so it really is going more towards the subject, and less 'just out into the room everywhere, while still maintaining the apparent origin from the practical.
To soften the shadow side of the figure on the couce perhaps some form of bounce just outside of the camera view on the left to put some light back into the face.
