[FS: General] Libec JB-30U Jib & Vivitar Battery Grip for 5DMKII
mozingopj
Selling this equipment to purchase prime lenses. All gear is in perfect working condition.
Libec JB-30U Jib Arm - $900 + SHIPPING
NOTE: YOU WILL NEED A STURDY TRIPOD FOR THIS SETUP. THIS KIT DOESN'T COME WITH A TRIPOD. IT'S ONLY THE TOP JIB PART. I USED THE KESSLER K-POD TRIPOD FOR MY SETUP.
The Libec JB-30 Jib Arm with UM-3 Undermount Adapter attaches quickly and easily to most conventional heads and tripods, giving it flexibility for use as a cost-effective studio crane where on-shot elevation is required, or on location where setup speed are critical. It provides precisely balanced booming with a load capacity of 44-lbs, from absolute ground level to 72-inch in height.
What's Included With This Item:
- Libec JB-30 Jib Arm
- Weight Bar w/Locking Nuts
- Under Mount Adapter
- 75mm Adapter
- Padded Carrying Case
The only cosmetic flaw is the end where the weights sit. The end cap cracked and I've covered it with Gaff tape. DOESN'T effect how the jib operates at all.
Vivitar Battery Grip for 5DMKII - $20
Take all the pictures you want without having to worry about losing power to your digital camera with a power grip from Vivitar. This deluxe power grip is made for the Canon EOS 5D MARKII. The power grip holds two LP-E6 batteries Includes an adapter that allows you to charge six (6) AA batteries inside Vertical shutter release button Easy power on/off switch Compatible with the Canon EOS 5D MARKII Model number: VIV-PG-5DMII
https://www.dropbox.com/s/p4r7fevq6mpy7e6/photo 1.JPG
https://www.dropbox.com/s/q4von990lsv6bva/photo 2.JPG
https://www.dropbox.com/s/m1oj8cs32sfygjb/photo 3.JPG
https://www.dropbox.com/s/d8s3nfq2pw6jcii/photo 4.JPG
New Prices listed in original post and here:
