LETUS35A - Screengrabs
rajtaylor
Hii...
I've been testing my new LETUS 35A adapter for a while and I am posting few screen grabs from the test shots...I have slightly CCd few shots. Please post your comments. Does anyone know an ideal setting for using lens adapters to achieve sharpness. Thanks in advance.
The new advanced seems awesome! ....Great bokeh and sharper this time around. Beautiful shots btw. Im starting to fancy this adapter now.
The Grain is due to the usage of gain and also because I forgot to switch on the adapter...These were shot in natural light and I guess under proper lighting, it wud really be awesome.
I used 2 lenses, a CANON 55 MM 1.2 open and a NIKON 28-105 3.5 open...somehow i was not able to achieve sharp focus with the NIKON. Any suggestions?
raj, love your composition.
i have a similar focus problem with my nikon lens... but only if i'm infinity focusing. I think the lens do well when you set up your subjects in a certain distance...
I crank my detail level and vertical detail level to +7 to compensate for the softening. Test it. Try it. See what works.
Those shots look great. I don't know why people worry so much about a slight softness or grain on those adapters. They look insane.
What are you planning on doing?
-Shorts
-Music Vids
-Feature
Good luck whatever it is.
I felt that all of these looked good in thumbnail form, but it showed lots of imperfections when blown up...to clarify my earlier comment
Thanks for your response guys...
The LETUS35A is really worth every penny you spend...With proper lighting, meticulous preparation and a proper set up I am sure we can achieve great results.
Malcomong...its a jpeg image and obviously when its blown, it tends to show imperfection...I intend to test the adapter with various lenses and will try to post you some more grabs in uncompressed tga or tiff.
I am also posting few of my dvx screen grabs (without adapter)...
Thank you once again for your response...
Cheers...
Raj.
AWESOME grabs man, what CC did you do on that stuff? I've been tryin to find a look kidn aimilar to that, grayness and desaturated colors, but every time i try it doens't work so well.
