You can see it here on Craigslist
http://losangeles.craigslist.org/sfv/pho/2169598223.html
email Dave@tvacom.com
This is a unit that I used on my Sony Z7U cameras and it works great. I have moved onto bigger cameras and dont use these units anymore. New this kit costs 1749.00. I am selling this unit for 1000.00 obo with 2 starter lenses. A 35-70mm and a 35mm. Unit works great. It is used but optics are all clear. I have never had any problems with it. If interested I am also selling a PL mount separately for 275.00 that has never been used.
The Letus35 Extreme Starter Bundle is an adapter bundle using the Letus35 Extreme adapter. This bundle offers the Extreme adapter, 45cm rod support system, and a custom case for location transport.
Note! The Starter Bundle has an optional Nikon mount for specific lens connectivity.
Extreme Adapter
The Letus35 Extreme Adapter is a lens adapter for 35mm still camera lenses to adapt for use on video cameras. This adapter allows the video camera to have access to prime lenses that create a shallow depth of field. The Extreme allows the user to work with an upright image.
Rod Support System
The Letus35 Extreme Bundle is a 15mm rod support system designed from user research and recommendations. This versatile system can be customized for many camera setups including large and small camcorders. As with any rod support system this setup allows optical attachments and lighting control devices to be supported by a sturdy metal base with adjustable rods as opposed to mounting via the filter threads.
Adapter Ring
The Letus35 is a specialized adapter ring for the sony Z7U (and many others) cameras filter threads. This 72mm ring allows the camcorder to work with the Letus35 lens adapters.
Custom Case
The custom case with this kit offers security and physical protection of the optical devices and mounts.
1000.00 OBO PL Mount is 275.00
Extreme Adapter
Rod Support System
Adapter Ring
Custom Case
