LETUS EXTREME 72mm w/ RAILs & Nikon Adapater
jonwolf
SELLING FOR $1,000 or b/o.
<a href="http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=130376178132&ssPageName=STRK:MESELX:IT#ht_1994wt_1098"> Check out on EBAY </a>
<a href="http://www.jonwolf.org/bean_hemlock.htm" >VIEW SAMPLES</a>
<a href="http://jonwolf.org/higheraspirations_color.mov"> Letus in Low Light </a>
This is a mint condition Letus Extreme 35mm lens adapter with nikon mount. Valued at $1,099
ALSO included are support rails. valued at $399
TOTAL PACKAGE VALUE $1498
It has a 72mm ring adapter that i have been using flawlessly with my panasonic hpx170. I have used this setup on 5 shoots. Works great. No cosmetic damage at all. No scratches. Includes small allen wrench toolset. Shipped to USA and CANADA only with PAYPAL.
VIEW SAMPLE FOOTAGE OF LETUS IN LOW LIGHT
Letus35 Extreme Features
New prism technology with proprietary Image Orientation Correction technology (IOC). This adapter "flips" the image upright
Highest optical grade achromatic lens (custom-made for this specific adapter)
Custom condenser specially tailored for this adapter to get the best possible picture quality
New and improved Ground Glass element
Beautiful film-look bokeh
Absolutely no vignetting
Best edge-to-edge sharpness in the industry
Stunningly beautiful image colors
Casing milled from solid aluminum
Anodized black finish
A sleek, built-in On/Off indicator with LED
Battery is fully enclosed and secured by 2 magnets for ease of replacement during a shoot
Virtually silent vibration system that will not interfere with microphones
Alignment is a breeze with the new and improved 72mm, 77mm, or 82mm ring design
Interchangeable thread rings and lens mounts for easy adaptation to different cameras / lenses on the fly.
Comes with your choice of mount (Canon FD, Nikon AI, Canon EF (EOS), Pentax K mount, Minolta MD, M42 Screw mount)
PL mount and OCT19 mount also available at a discounted price if selected as the primary mount on the Extreme.
Hex key for adjustment/installation
End caps included for protection during transport/storage
Light switch brought to the back to avoid distraction to those in front of camera
Threaded hole on the front tube for matching up to support systems
The New Letus35 Support Rods raise the standards for camera support systems. The entire design is based on feedback and recommendations from real world users. The complete package is custom milled from solid aluminum for durability and precision.
The Letus35 Support Rods is a highly versatile camera support system that can be customized for a myriad of camera setups. Each part of the system is highly configurable for individual needs.
It features a quick release camera plate that can be adjusted both side to side and back and forth. An 80mm solid aluminum tripod mounting block that can also be easily adjusted back and forth for balancing loads. Two 90mm camera riser supports to adjust camera height as needed. The Letus35 Extreme support bracket is also included with the package along with an upgraded custom milled thumb screw.
The complete package rides on 30cm or 45cm silver anodized aluminum rods. Additional rods such as our 15cm accessory rods can be added with our red anodized couplers.
Letus35 Support Rods Features:
Precision milled solid aluminum components
Quick release for camera plate
Fully adjustable camera plate in both forward/backward and left/right movement
90mm height camera support risers
70mm height Letus35 Extreme support bracket
30cm or 45cm silver anodized support rods
Optional 15cm rods with 2 red anodized couplers
Red anodized support rods couplers
Industry standard 15mm diameter on all components for third party accessories
