Letter Box or Squeeze frame?
KimCamera
I'm going to shoot a feature length movie in the near future. I have the anamorphic lens and will purchase the wide-angle lens for my 100A. An editor will edit on a G5 with the latest Final Cut Pro software, probably DVD Studio. I'm going to shoot in 16:9 24fps Progressive mode. I eventually want have the option from the mini DV master to make 16:9 formatted DVD's and transfer to 35mm film.
My question is; what mode will you suggest to shoot in-letter box or squeeze frame? Should I use the anamorphic lens or just use the wide-angle lens? Thanks.
If you're thinking film transfer, I'd say that you should start practicing with the anamorphic right now. The extra resolution will really com in handy. Don't use squeeze mode, because the resolution loss it causes will be very evident on a 35mm print.
It'll work on DVD, too. The workflow will vary depending on what NLE and DVD authoring programs you're using.
