I have exprienced more dropouts with the G3 over the years than from my Rodelink sets.
I have Lectro 411s, 211s (+ an old 185 for sentimentality, though it still works good) and some G2s and G3s. The newer SHF (GHz cellular frequency) systems are easier to set up frequency wise, but they come with their own set of issues and may be better for folks with little frequency selection knowledge.
The Sennheiser G2/3 100 series seems to be the standard for a low cost system. Most of my pro film sound colleagues have some for hops, seconds, ect. The competitive Sony is noisier, but decent otherwise. Neither come with pro quality mics.
An external scanner should be used with a G2/3 system in suspect areas... the Rx internal scanner is inadequate for detecting all but very high modulation.. I've used G3s in mid-town Manhattan (aka, RF hell) w/o issue with the aid of an external scanner.
Another common cause for dropouts is the Tx antenna in contact with the wearer's skin. That can significantly reduce RF output.
In lieu of an external scanner, at least consult the Sennheiser (or other) up-to-date Frequency Finder to find and avoid frequency ranges in use by OTA TV. Choose a channel that is 'vacant' (best), or has a modulation of at least -80dBm Prx (good).
Praying to the RF gods is another option.
Simple question: All about the same money here, so...
Rodelink filmmaker kit
or
Sony UWP-D11
or
Sennheiser G-3
Always borrowed before, but time to spring for the basic wireless kit.
I cannot recommend that Sony system mentioned above, if it's the one I think it is. Working on campus of major energy company two days in a row. Day 1, fine. Day 2 (different room), terrible. Weak signal, scratchy/squealy audio, etc. Yes, I did a scan. Was probably 10 feet from talent on the bad day.
