leonidas7576
hey all,
i have a les bosher, arri standard to PL adapter, designed specifically for cooke speed panchros- ser. II and III (this involves two spring loaded pressure points and a locking arm at the rear of the adapter, to keep the lens situated within the mount while focusing). i'm wondering if anyone has used this adapter in conjunction with either a cieco7, MTF, or Hot rod (or others) m 4/3 to PL adapter. My concern deals specifically with the thickness of the tabs (2mm when i measured) on the les bosher adapter, and the depth of the locking element on the cieco7, mtf, and hot rod PL mount.
(I ask because i tried using it on a RED PL once, and the adapter tabs would not fit completely into the PL mount- the tabs were too thick for the depth of the mount to lock over them. its worked fine in other pl mounts.)
any and all information is appreciated. Thanks!
best
g
best
g
