Joshua Provost
I'll try not to make this another favorite lens thread...
I'm having trouble choosing lenses for my new (used, but new to me) AF100. I'm trying to relate what I know of film production (not first hand, but through reading every issue of American Cinematographer for the last ten years) and apply it to my lens choices. I'm tossing out any comparison to full-frame 35mm and going just based on cinema shooting assuming that the AF100 sensor and Academy 1.85 are within 10% of each other (and within 20% of Super 1.85).
A couple perspectives:
Focal Length - If you survey the cinema prime sets on the market, the middle of the road lens is always around 35mm focal length, and most DPs I have talked to use a 40mm or 50mm as their standard lens, and consider other lenses wide or tele in relation to that starting point.
Lens Speed - Cinema primes are usually T2.1, but T1.6 is also common and faster lenses are available. I often read about DPs working to shoot no faster that F2.8 so they don't kill their focus puller, and lighting to get F4 or F5.6 in certain situations. You do read about shooting F2 or faster from time to time, but generally this is out of necessity to get a shot by low or candle light, and not an aesthetic choice per se.
Given all that, it would be nice to have a set of m4/3 primes that included around a 28mm (wide), 50mm (middle), and 85mm (tele) or a zoom lens that covers that range. I could get the Olympus 75mm and 45mm and the Panasonic 25mm and have a set pretty close to that and work down to F1.8 across all three lenses, but at around $1800.
Alternatively, there are the Panasonic zooms which are F2.8, but I'd almost have to buy the 12-35mm and the 35-100mm to really covers a normal range of shots, and that at a cost of $2500.
So, the question is for people with experience shooting narrative features or shorts with the AF100:
Is F2.8 really good enough for cinematic depth of field (comparisons above would indicate it is just fine)?
What do you consider wide, standard, tele?
What was your decision-making process in selecting the lenses you use?
What do I lose if I jump ship on the m4/3 lenses and get a Canon or Nikon 24-70mm F2.8 lens instead (which better covers what I would consider a normal range for filmmaking)?
