Lens choices for FS700
Colinelves
Hi Guys,
Currently I've got a set of cheap M42s (not M43!) for my FS700:
16mm f2.8, 24mm f2.8, 28mm f2.5, 35mm f2.4, 50mm f1.4, 85mm f2, 135mm (f2.5 and f3.5) and 300mm (f4)
On the plus side they were cheap (approx £700 for the lot), most are a little faster than a zoom, they covers a reasonable range and they are generally okay quality (except the 24mm which is awful until f4!) I shot a low budget TV pilot on them and it all looked great (apart from one wide shot which I needed the 16mm for and was a tad-too fish-eye-ee)
Anyway. The point is, they're not great, I'd rather not use them if I have the budget to get better glass and I can't hire them out (like I do the FS700, via a local rental house) so I'm thinking I should sell the lot and buy a couple of lenses that I will use and can hire out.
Having killed £12k on the camera and various bits to go with it, I've only got a budget of around £1000 (after selling the above). So I'm looking for some advice/suggestions. The rental house I put the FS700 out with has 5Ds, with Canon zooms and a couple of Zeiss SLR primes and a full set of Nikon AIS converted to EF, but no Canon primes - so Canon stuff might be good as they'll rent it out with the 5Ds
At the moment, here's the lenses I am thinking about:
Canon EF 50mm f1.2
or
Canon EF 85mm f1.2
or
Canon FD 50mm f1.2 and FD 85mm 1.2 (then paying for a conversion to EF mount and film gears, aperture etc)
or
Noktor E-mount 50mm f0.95 (might be good for the slow mo and super shallow DoF)
or
Zeiss 24-70mm f2.8 zoom with LA-EA2 (the phase detect auto focus might be desirable for low budget steadicam and hand held shoots)
So, yeah. Have I missed something? I guess I'm asking what you guys think will have the greatest demand.
Cheers,
Colin Elves,
DP & Steadicam Op
www.colinelves.com
I have a Tokina/Angerieux 28-70f2.6-2.8 - if you can find the first gen sometimes they go under the radar as there's so many Tokina versions that look the same at a first glance (but the Tokina versions are 2.8 only) in Amount + adpt it has auto focus
A bit of a rare beast to find, but incredable glass for very little investment.
Thanks Dermot, the hire company already has a couple of zooms that go out with the kit. Plus I have the kit lens. I was really just thinking of the Zeiss zoom because it is Zeiss and (I think) has the phase detect auto).
Hi Guys,
Canon EF 50mm f1.2
or
Canon EF 85mm f1.2
or
or
or
Cheers,
Colin Elves,
DP & Steadicam Op
www.colinelves.com
Well it really depends on a lot of things. For photographers, there's no better dream then 5D+85 1.2. But, for video 85 is not that good, mainly because the focusing is electronic. You still use the ring to focus the lens, but there are no gears inside, instead the lens has electronics which translate ring movement into focusing changes. So, using follow focus can be problematic.
So, for videographers, I'm guessing a 50 1.2 would be in higher demand. I own both and as much as I like using 85 on 5Ds, I prefer the 50 1.2 more on FS700, as well as 24 1.4 and 35 1.4 (there should be a V2 of the 35 coming soon). Can't comment on other lenses as I've never used them. Other stuff from Canon that could be interesting is the 100 macro 2.8 IS II - a great lens for product shots, closeups, portraits etc. with very nice stabilisation, and of course the 70-200 2.8 IS II, but I think that's a bit out of the price range.
Unfortunately, Canon still doesn't offer 24-70 2.8 with stabilisation - I'm guessing that lens would be a top seller.
Yeah, it's tricky. At present I'm leaning towards the Tokina 11-16mm as it can be useful on drama and architecture to have something really wide when using S35 and the widest the hire company have is 16-35. Then maybe a Nokton 50mm f0.95 just because I've had two separate clients talk about using the FS700 for lpw budget slow mo night shoots (which is just crazy!)
i see no appeal to EF glass at all (it is great for still photos on an AF canon body of course!)
I dont see why you need to get FD glass EFd
Id get old primes and consider one Sony AF/VR zoom..
S
I have this lens too. What a great lens, flares a bit more than modern lenses, but has an aesthetic that's hard to beat. Make sure you do your research to get the actual Angeneuix design.
S
If it was just a question of gear for me I'd just get the Zeiss zoom (the kit lens is a bit slow for my liking) or possibly a set of old Canon FDs with adapters. But I'm thinking about maximising the rental income from the lenses and the company I rent out through has a bunch of 5Ds, so Canon glass will go out with them - effectively doubling the rental income. So, for me, it is a balance between lenses that are really good to match with the FS700 (like the Nokton E-mount) and those that might also go out with the Canons.
I recommend on leaving all canon ef lenses for photography. Those lenses are designed for taking fotos with autofocus, the manual focus ring is only useful on adjusting the focus after autofocus. So none of them really work for video. Even tokinas lenses have better manualfocus ring than canon. If you get new ones, get zeiss with metabones.
i got the 16-80 sony alpha zeiss with ae2 adapter, it is okay, but noisy, backfocus is off on zooming and it is not fixed aperture, but it is better than the kit lens.
11-16 mm tokina is good, but a bit too wide to be used on any real projects. Zeiss 21mm is nice on fs700 as is the 35 zeiss (for video the 2.0 hence 1.4 has too much CA).
as could many nikkor contax etc
I agree with the above poster, any one who thinks EF lenses are any use for filming has been drinking too much fora Kool-Aid rather than shooting.
I film with EF and Zeiss lenses all the time with my FS700. The EFs work perfectly fine. Sure they are better for photography, but you can certainly use them for video. Manual lenses are have a bit better focus ring, but EOS lenses are perfectly useable.
I mean, RED, C300 and BMC default with EOS mounts. Tons and tons of videos have been filmed on the C300, 5Ds, 7D, etc... and there has been lots of amazing work done with EOS lenses. Basically, with the huge body of work on Vimeo done with EF lenses, it shows that if you cannot film with EF lenses, basically it just means you don't know how to shoot because it's pretty damn easy to video with EF lenses.
It's not the lenses, it's the filmer. Like I said, Manual lenses are more ideal, but EF lenses work fine.
I have to disagree with you. The only reason to use EF lenses is if you already own EF lenses and can't rent others. The usability aspect of all manual primes (let alone dedicated cine lenses) is a HUGE thing while shooting.
There's nothing to disagree with JPM. I said in my post that Manual lenses are better suited for video, but if you have EF lenses they are perfectly useable for video. There are tons of really good video that have been made with EF lenses, so it's very obvious they are fine for video. Not as good as manual lenses perhaps, but still very useable.
Gene - its very far off topic to argue with you. So I wont.
I would also suggest EF (and equally other AF) lenses dont last very long, especially under the rigours of daily hire use.
IS/VR is useful in some situations for filming however.
S
Using high quality primes is just one way of shooting. It bugs me when people automatically equate "their way" to be the only way. EOS lenses are great and I do not miss any high quality film primes. Why not? Because I usually shoot and operate the camera alone. I need to be fast and good, heavy ass lenses do not fit that equation.
Using high quality primes is just one way of shooting. It bugs me when people automatically equate "their way" to be the only way. EOS lenses are great and I do not miss any high quality film primes. Why not? Because I usually shoot and operate the camera alone. I need to be fast and good, heavy ass lenses do not fit that equation. I've been using some only manuals (like the Samyang 35mm f1.4) and still lenses with bad focusing and still I've pretty much gotten used to the way to focus even on fiddly-diddly focus rings like on some Sigma and Canon lenses. You guys make it seem like it's rocket science. It ain't. It's just a wheel. For example I think the focus on the EOS 100mm macro f.28 Canon L lens is almost excellent. Only problem is medium distances where very little movements move it a lot. But for macro work it just works.
Also the IS on that 100mm really, really rocks. I doubt you guys and your "excellent cine-lenses" can get handheld macroshots like the 100mm can. Or atleast with the speed a capable user can do.
What about 3 new Sony E-mount Alfa lenses ?? I'm looking for two of them: Sony 35mm f/1.8 OSS Alpha E-mount Prime Lens
and Sony 10-18mm f/4 OSS Alpha E-mount Wide-Angle Zoom Lens
Image Stabilization and autofocus for that range seems reasonable, a specially for use them on Steadicam shoots... What do you think of it?
