After I apply Time Shift to an audio clip, it does a great job of slowing it down. But the clip doesn't actually get any longer in the timeline. So after the slow-down, it ends abruptly, and I can't figure out how to extend the clip in the timeline any longer. The original clip was only 3 seconds long, and the slower clip is still the same length (just with slower sound in it).
When I listen to the audio Preview in the Time Shift plug-in window, I hear a full, longer version (about 4.5 seconds) of the slowed down audio clip. But again, it won't let me lengthen it in the timeline. What's the trick?
EDIT: Okay, as so often happens, I struggle with a problem, and then finally resort to posting the question on DVXuser...only to then suddenly stumble on the answer. And such is the case again. It's a strange fix though! So I use the "master clip" option, by dragging the original audio clip over onto the AudioSuite Window. This opens up the "master clip" options. And then if you check "load result," Avid will automatically load the rendered audio clip in the source window. And that new clip is the full, new length. Note to AVid: that's too complicated!
