Do any of you 'wrong-eyed' shooters have a 'work-around' solution for the HPX 500.
Short of machining a new piece, i'm stuck, and my neck is getting sore.
Any help out there for us 'left eyes'?
Thanks.
I have a HPX300 and use my left eye always. Just shifted the viewfinder as far as possible to the left. It would be more convinient if you could shift it another 1 inch further to the left. In the case of the hpx300 it is not possible to make an adapter to increase the shift range because you will get in the way of the mic holder (just look at the cam and you will understand) and the viewfinder will shift further towards the lens end and this makes it even more inconvinient to use. So i can manage with how it is now. The advantage of using your left eye is that your right forehead (at least in my case) touches the camera body and you can make a much more steady shot.
