I'm trying to put together a relatively simple lighting kit. A basic starting 3-point setup is probably ok. But I have one big requirement. I hate hot lights and I will not use them, end of discussion. I also don't think I'd like HMI due to the ballast. EDIT: If the ballast was integrated or small/attached it might be ok.
Some friends and I want to shoot some short films within the next few weeks. I've also always wanted to put together a lighting kit for interviews and random video/photography stuff. A few years ago I bought a 650w Altman fresnel thinking it would start my kit but I was so turned off by the heat that I kind of lost interest in filmmaking. Recently I've kind of got the itch again with all these LED panels coming out, and I was thinking...
Would this setup suffice: 2x ePhoto/Fancier 1000 LED 5600K panel for key/fill and 1x 500 LED 5600K for backlight/highlight. Or should I use some florescent? I *think* fresnels would be preferable since you can control the light more but they're so expensive. Would it make sense to bite the bullet and get 1x Arri L7-C Color LED Fresnel and a couple of the cheap LED panels for fill/backlight? Or is that just silly to mix the best with lower end?
EDIT: I've actually reconsidered a bit. I think I'm going to go with a couple HMI/CDM fresnels and then some flo banks. Should keep the heat away.
