Learned something the hard way today...
davideo.net
I was shooting a corporate video today with my 300 - just in DV mode and 4x3. I was interviewing "associates" of a major company and each interview was about 5 minutes. I was running the camera off AC. After one of the interviews was over, I was JUST about to pause the camera when the power went out in the entire town. I put a battery on the camera to see if my last interview was there, and it was totally gone - like it never existed. So: message to self and to you all - if you're going to use AC power, use it with that Anton Bauer Tandem AC adapter/battery charger unit WITH a battery attached. If the power goes out, the battery kicks in and continues the recording. I learned the hard way, and will never leave a battery off the Tandem charger again.
http://www.antonbauer.com/Products/Tandem
Update 7/26/09: I'm glad to report that I'm wrong! "Repair clip" in the thumbnail menu is your friend.
That doesn't sound right at all. On my HPX170, when the camera loses power, all it does is not write the header to the file to close it. I can use the repair clip utility in camera and it has always fixed it and I have even done it on purpose to test that the camera will save my rear. It always has. I know that Jan says the most of a P2 clip that you can lose is 2 seconds, because P2 backs itself up every 2 seconds.
I don't have a 300 here but I would be amazed if Panasonic made a camera that sells for throusands more than my 170 not be able to recover a recording from a power outage. That happens all of the time.
1. Did you re-format/erase the card already?
2. Talk to Panasonic/Jan and figure this out.
3. I would test this on another shot, just do the same thing on purpose (not on a real shoot obviously). You should be able to recover the file with no problem, I always have.
Dan
Definitely try the "repair clip" function. I've repeatedly tested yanking the power out on multiple P2 cameras, and it has *always* salvaged the entire clip (minus the last second or so).
I haven't tried it, but I'm sure you guys are correct. That repair function is not in the camera menu, but in the thumbnail menu, by the way.
