PaDaddyof3
This video explores aspects of using the XH-A1 in depth. And because the instruction is programmed it constantly builds your knowledge to help you not only understand but remember the myriad of taping and still photo possiblities this camera has to offer. Let's face it, the XHA1 has so many possible setting combinations that it is daunting.
This video is so good, that if you have to shoot a wedding or movie in few days, watching this will make you feel comfortable about your ability to use the camera. Neither of the other two videos can say that.
101 minutes (1 hour and 41 minutes) 42 Chapters.
A * below indicates a chapter heading.
This DVD covers:
*Accessories--cases, inexpensive lenses to protect your expensive camera lens, and more.
*Getting Started Taping--basics of operation
*Batteries--this is the only video covering battery handling.
*Tapes - this is the only video that shows tape preparation.... Along with tapes DROP FRAMES are defined and you'll learn the right way to determine if you should set your XHA1 to DROP, or NON-DROP, something the other videos don't do.
*Emergency Reset - how to reset the camera. This is the only video that covers the CORRECT and SAFE use of the under- LCD-display-recessed reset button.
*Date & Time--how to set up your date and time.
*VCR Controls--you'll start using these right away as we finish up tape preparation.
*Camera Settings--how to set up your camera so that you can follow along in the
programmed instruction.
*XLR Input - this is the only video to show how to set up XLR connections.
You'll see how to set your camera to 24f if you plan on transferring to film.
*ND Filters --discussed with filming examples.
*Standby/lock -how to control taping.
*Auto & Green box --the auto modes compared.
*Tv, Av, and Manual--demonstrated visually.
*Spotlight & Night Modes--the benefits and weaknesses of these modes. This is the only video that discusses these.
*Manual & Auto Focus--what they are and how to use them.
*Position Preset--how to set up and use focus and zoom presets.
*Peaking & MAGN & Display - these focusing tools with black & white options are
discussed and demonstrated and the display options discussed.
*SD Card Save Experiment - in this inventive first demonstration of how to save to card, you'll learn about direct to computer output.*White Balance-in more detail than you'll find anywhere else. You'll see how to use White Balance and colored gels to get an outdoor/indoor shot.
*Exposure Lock--learn how this tool can help get the perfect mix of light.
*Manual Gain Controls--see how gain can be used and how to set values for the manual settings.
*Sound Recording Controls-- how to use the MIC attenuators for problem sounds like gunshots and more.
*End Search &Review--how to preview what you just shot without loosing your place at your last recorded frame.
*Zoom Controls--both the variable and constant speed zooms are demonstrated.
*Still Camera Features--everything you need to know about the fantastic still camera built into the XHA1. Includes everything you need to know about SD card handling.
*Cables--discusses the cables that come with the camera.
*Recording & Display Setup --learn about the rest of the recording and menu display items.And learn about UB tape naming techniques.
*Custom Keys-see how to set up custom keys.
*Zebra Pattern-this is the only video that demonstrates how to use the zebra pattern for correct lighting.
*Advanced Time Code-shows how to use REC-RUN PS, why it is better than the UB method of naming tapes, and an in-depth demonstration of what FREE-RUN can do.*Camera Setup Redu--finishes up by demonstrating important camera setup items
*Skin Detail-this is the only video that shows what you can do to teach yourself how to use the skin detail feature on this camera.
*Color Correction --you'll love this in-depth demonstration of color correction. Here it is used to create a black & white world where ducks have pink bills.
*Clear Scan - learn how to tape your television or computer screen.
*Custom Display & Custom Functions -- learn how to save the custom display settings discussed earlier in the video and more on what you can do with custom functions. (Also discussed, as needed, earlier in the video.)
*Custom Presets -Finally, you'll learn how to save, name, change, and find these wonderful settings that can give your video a film look, or any other look you want.
