Lcd Monitor
twocik23
I found this Camera Mountable LCD Monitor to use for my 35mm adapter. Now it says that the monitor's image can be horizontally reversed or vertically flipped. I know that its resolution is only 1152 horizontal x 234 vertical, But it can be flipped. I was going to mount the lcd upside down and push the horizontal button, so that the image is normal again.
Any suggestions on this setup ?
http://www.bhphotovideo.com/bnh/con...s&Q=&sku=276812&is=REG&addedTroughType=search
Well, I was wondering if anyone has tried it out or if it just flat out sucks. I'm not familiar with this company (tv one).
Oh, okay. In that case, I won't be able to help. I'm looking for a similar item for the adapter I'm getting. Also, you won't need to mount the lcd upside down would you? Tim.
This is the thing, is that it can only be horizontally reversed or vertically flipped NOT BOTH which sucks. So I was just going to screw a hole on the top and flip it myself. Then press the vertically button and the image would be back to normal.
For that amount of money I'd look at the Varizoom 7" LCD. It has x/y flip. Monitor alone is around $380 and you can get a kit with a rechargable battery, shoe mount, etc. for around $460 at B&H. Brian Valiente at Redrock just got one and really likes it. He's posted about it on their forums.
Fox
