Yes - replace the Sony90 degree clamp with one that has 2 lockdown nuts:
http://smallrig.com/smallrig-90-degree-angle-rail-clamp-15mm.html
It helps
Yes this is really starting to piss me off! Who designs a viewfinder with such a useless system? It's nearly impossible not to tilt it sideways and screw your horizon and the little level guide in the EVF only helps so much. At some point it just gets old to have to keep redoing it. I only have the camera for a week but it has annoyed me to the point of making me consider buying a real viewfinder, since the LCD itself is also not the best. But then you also want to buy a new shoulder system because the stock one is not that good and when you realize, the $8000 deal is not so good anymore because it's looking more like $10000 or $13000 or even $15000. It was supposed to be the camera ready to shoot out of the box.
Anybody found any workarounds to lock the sucker in place?
I've not had a single problem with this happening. Perhaps there's a QC issue with the rod and clamp?
I saw another guy's clamp in person, and we pulled out the pins.. it looked like the holes drilled into his clamp weren't quite as deep as mine, which meant the little pins stopped short. So yes, his weren't engaging on the grooves in the rod.My suspicion is that on some units the grooves don't "click" properly every 90 degrees. For some reason when I first got it I did not even notice or hear that they are suppose to click into place. Could be that the clamp doesn't always work or maybe the mechanism gets stuck.
