De Filmboetiek
We where trying to find a solution to flip the image on the LCD screen. It cant be done in the software. so i was looking to get an external LCD ...
But really, the quality of the LCD screen on the EX1 is sooo good. I havent seen a match for it, unless your spending $ 2000. another problem is that you will lose the expand focus function on a external monitor. Aswell as having to use the analog outs (which sucks because of its placement) or carry more power adapters. And then .. where to put the LCD ?? On the flimsy hot shoe, where its in the way of the mic holder ?
But as i said, it was all too easy .. Just flip out the LCD. Take a precision Phillips screwdriver, and remove the plactic cap, thats over the mount for the LCD. Inside you will see a miniature switch which toggles the the LCD flip mode, used when turning the LCD towards the front. Now just jam the switch and the LCD is flipped .
Professional solution? No, but working. Step 2 will be to make a mini switch witch by passes the automatic one ... But really, i cant believe Sony is having us to go trough this .... Bot ok, this is not a professional camcorder ..
Alex.
Alex.
