Don't know of, have never heard of, or encountered a 'locking' 1/8" extension cable. Some locking plugs can mate to a non-locking cable.. Don't know of, have never heard of, or encountered a 'locking' 1/8" extension cable. Some locking plugs can mate to a non-locking cable.. but the stock molded-on ME2/4 Sennheiser plug ain't one of them. How about an XLR hard-wired lav or a 1/8" to XLR Phantom Power or battery adapter cable?
Absent specific identification, assuming you are talking about 3.5mm "stereo" (3-terminal) connectors with locking rings....
You can make (or have made) cables with locking male 3.5mm "stereo" (3-terminal) connectors on one end.
But I have never seen a cable-end female 3.5mm jack with exposed threads that you could use for the locking ring.
You could use a standard cable-end female connector and use gaffer's tape to hold the connectors together.
when having to use non-locable connectors, hold the two end close and cross the cable. Bring one under, as if tying a knot, and the plug them together. pulling on the ends forces the two together, not apart, making accidental pull-out unlikely.
Markertek.com carries both male and female locking 1/8" TRS cable end connectors. They also have a custom cable shop and can make the cables if desired.
http://www.markertek.com/Connectors...onnectors/M-3-5S-LOCKING.xhtml?M-3.5S LOCKING
http://www.markertek.com/Connectors...-5mm-Adapters/Calrad-Electronics/30-297.xhtml
Markertek's Tecnec 1/8" TRS male plug will also mate with a non-locking female jack, whereas Sennheiser's moulded on plugs will not.
FWIW, Markertek/Tower Products (Saugerties NY) also owns and manufactures the Sescom line of products. Acquired a few years ago after the passing of Franklin Miller .
Don't forget that the cable from mic capsule to wireless transmitter is unbalanced. Adding an extension cable of any length opens you up to electrical interference creeping in on the cable.
The Tecnec Plug and Calrad jack are compatible. According to Markertek, "30-297 - Locking inline 3.5mm female stereo, Mates to M-3.5S LOCKING plug" ... which has the same threads as the Sennheiser molded-on plug.The threads on those connectors may or may not match the ones on your equipment. They look rather more coarse (and smaller diameter) than the ones I use.
