Latest SonicStates GH1 footage - BIIIIG Size
SonicStates
It's ready and small it is not...610MB...
As mentioned 12 shots, you can get the info in a text doc. here:
http://gh1.dark-stone.com/sam/Intact...ettingsSam.txt
Here is the latest footage:
http://gh1.dark-stone.com/sam/Intact/PRIVATE.rar
I'm not by any stretch of the imagination a pro so bear with any F-ups on my journey to become better.
The first four shots were done in my studio (audio) so forgive the monotony...at least you can have some music to listen to while seeing my space...4 different settings (see link)
The next lot were done at Nagoya station (got some blue sky for GreGory) with a combination of static shots (hand held), soft, medium and nauseatingly fast, hello-jello pans (although I don't really know how they turned out because I haven't seen any of this stuff yet). All done in 1080
As per usual, a big hats off to Daniel...my welcome must surely be running out after this upload ;)
Enjoy...and next stop is the LIST chicago kindly put together to make sure I wasn't bored on Saturday afternoon...at work. Nah, seriously I really enjoy getting more intimate with this cam...it's been a pleasure so far except for the lens cap which drives me crazy.
Cheers,
Sam.
IC: maximun
IC: maximun
thank you very much for the footage. i am downloading it now.
just a question: what is IC:minimum and IC: maximum in the text file information?
thanks a lot...
Sorry that was my bad it should have been IE, Intelligent exposure. Will get onto the FOV test as soon as I can...probably tomorrow afternoon along with the other requests.
ProRes'ing the files now. The private folder works perfectly in fcp. Recognized it without being told where to go. Perfect, Thanks Sonic. and thanks for writing a seperate doc for settings info.
Ooh, I really love the daytime exteriors in this one. Playing around a bit now with some color correction and other stuff. Thanks!
Finally, FCP works. :) Not only that but I removed the pulldown with JES and I'm watching this with no interlaced ghosting or artifacts. Your 24P handheld studio footage looks very good to me and I think it's pretty useable.
Boy, still can't believe this is shot at 800 and 1600 iso. Blows my mind...
Gotta say thanks for the this Sonic. Proresed the files from private folder took about 18min for the 12 files. Then removed pulldown and conformed to proresHQ took 15 min 10 sec for clips 3,4,8,9,10, 11, and 12 on my core 2 duo macbookpro.
My feelings are the 1080 24p looks just great, its not just wishful thinking. You have to remove pulldown to see these clips in all their glory because viewing the 1080 24p in the 60i stream you will see alot of aliasing. This disappears when you conform to 23.976 in compressor
Moire seems to crop up from time to time. Rolling shutter on those quick pans, and I thank you again Sonic for doing that, is there but minor and acceptable to me. Be aware that only two 1080 clips were shot at shutter 1/50 ( the closest standard filmlike shutter setting) and only one of those an exterior with pan.
Other than fcp making me go through hoops to get there I love this in 1080 24p. Hopefully updated FCp makes this easier. And Sonic , big props to you for doing this and Daniel for the upload.
If as I read you are willingly doing more uploads, if you can give more 1/50 shutter at 1080 24p it would be great.
Sounding good!
Yeah I was a little leery about winding the ISO up like that but so far the comments proved to warrant doing it for less light shots.
Glad to hear FCP is cooperating.
I just read the thread on the shutter so you can expect the arbitrary winding to stop...at least for the most part :) ...1/50 on 1080... right on. At least that part is clear...
The 720 stuff I guess will have to be shot at a 1/60 or higher to avoid the frame doubling which happens if you drop it under 1/60. If that's the case, no big deal...I'll be looking for faster glass though for less light shots.
Sonic I think there was only one shot exterior that was 1080 24p at 1/50 and if I'm correct it was a slow pan on the corner to someone handing out leaflets. The gray stone wall in slight shadow is showing some compression issues.
According to your settings OIS was on and film mode was vibrant. Can you turn OIS off for some of your tests and set film mode to a middle setting. The codec may be being pushed to hard.
Trying to figure out if its me or the shot creating it but anything making the codec work harder should be considered.
What I am starting to notice is on tilts (up and down) the footage stays relatively sharp...and even with people walking back and forth moderately. It's only when panning you start to get some issues with breakage. But so far nothing like what I seen with the train footage. I wonder if this has anything to do with the type of shutter this camera uses (rolling from top to bottom)?
Is noise reduction ON or OFF in the footage ? That could explain lot of fine detail removal (like 00007.MTS, ground details in the street), it seem to be blurred as if NR was ON. Can you confirm ?
However, 00004/00005/0006.MTS looks razor sharp, which makes me think 1080p24 could produce nice things with proper settings ?
Don't know if its breakage but if theres a detail setting setting and its set too high it will cause a SNAP to sharpness when you pan which doesn't look normal. The occurs with the Sony EX1 when setting the detail level too high.
Sonic is there a detail setting and what have you set it too if it does.
A high detail level would also cause the moire issues and any aliasing that remains, so reducing it might be very helpful if its possible to reduce.
please tell me a way to get rid of this pulldown thing
this alising is very annoying
as easily as possible
please
I have windows xp
Isaac, can you post JES Settings here or in the WorkFlow area?
(or link me please if posted, JES = too short to search on User)
It would be great if all this "aliasing" talk was just not removing pulldown properly - and FCP does not do it on transfer. I have my settings at AVCHD to ProRes with remove advanced pulldown checked and I get 29.97 interlaced files.
If JES is identifying the pulldown properly that may be the missing link. Wary of doing Comperessor to 23.98 as I'm concerned it's going to randomly drop frames.
Anyway, need your JES settings if you can please. My head nearly 'sploded when I openned the app and saw all the options.
In my experience JES is usually more intelligent about finding the cadence and removing pulldown. When I first got my HV20, I was discovering occasional interlace combing in my footage after processing it with Compressor (the 'recommended' workflow), but JES handled it fine. That having been said, the only GH1 footage I've tried processing the same way with JES did have artifacts remaining. I'm not sure why that is, it could easily be something I'm doing wrong I'm sure. The Cineform NeoScene demo seems to do a good job of it without additional fussing, for what it's worth.
