SOLD Large Pelican Storm Case + Zacuto Customizable Foam Insert
Status
Not open for further replies.
Dillon Novak
SOLD
Very good conditions/some scratches on the case from average production wear
Foam is in great condition. Completely customizable to fit a wide array of cameras
PLEASE EMAIL IF INTERESTED DILLONNOVAK@YAHOO.COM
I DO NOT CHECK MY DVXUSER MAIL THAT OFTEN.
THE CASE
(http://store.zacuto.com/storm-case-im2975.html)
Five Press & Pull Latches
Three Double-layered, Soft-grip Handles
Two Padlockable Hasps
In-line Wheels
Telescoping Handle
Vortex® Valve
Flush Powerful Hinges
Lightweight Strong HPX® Resin
Watertight
Guaranteed For Life
Dimensions:
Exterior Dimensions (LxWxH)
31.3 x 20.4 x 15.5 in.
795 x 518 x 393 mm
Interior Dimensions* (LxWxH)
29.0 x 18.0 x 13.8 in.
737 x 457 x 349 mm
THE FOAM
(http://store.zacuto.com/panasonic-sony-handheld-studio-foam-insert.html)
"Either of our three camera packages Cine, Studio or Studio Handheld will fit into this foam insert fully assembled. Foam insert fits Storm IM-2975 case, not included. You can go from the case to the tripod to handheld in just seconds. This case also holds 4 additional camera batteries, 2 camera battery chargers, wide angle lens, telephoto lens, or 4 prime lenses, filters, 4 additional P2 cards, Firestore or P2 store, BT-LH900, Marshall, Nebtek HD monitors, Full Zacuto baseplate system, Zacuto shoulder pad w/Q-release, zoom controller, whip, two 90 Watt hour batteries with hotswap, dual charger for studio batteries, Zacuto Zgrips, Z-Mount, Zacuto whip, large and small Zamerican articulating arms, remote, manual, & accessory compartment.
Three prime lenses can fit in the lower level of the case, see view more images on the left. Then replace just one layer of foam plug in each compartment on top of inserted lenses. Finally, insert upper layer items as seen in top picture on top of lenses. These three lenses plus the lens on the camera will allow you to include four prime lenses in this case. Lenses in lower lever are fully protected. The hard case is available for purchase and may be selected below."
Status
