Lenilenapi
Carbonite Member
Here's a bunch more questions about laptop workflow that affect what kind of laptop I purchase.
I am limiting this to Apple powerbooks BTW. FCP refers to Final Cut Pro 5
1. I understand that 1.25 or 1.33GHZ processor (maybe even 1GHz) is sufficent to download P2 cards to a laptop.
- Does speed make a difference though? Will a new 1.67 Ghz proc transfer P2 cards significantly faster?
2. I understand that 5400RPM HD is fine to record HD data, but 7200RPM HD is neccessary to playback HD . I assume clients will want to be able to playback in the field
- Does processor speed affect ability to playback HD on the laptop - are there minimums?
3 - I'm a little confused about the files once they get on the laptop.
-If you download directly from P2 cards then you are not going directly into FCP right?
-What are the files then, Quicktime?
-Are there different requirements in process speed and HD RPM speed for Quicktime playback vs FCP?
-I've heard about losing "Metadata" in Quicktime. What is this & does it matter?
- Can FCP directly access these files or do they have to be imported into FCP & does that take much time?
4. If you capture thru Firewire into "Capture Now" in FCP are you making a different kind of file than the P2?
5. In either workflow (P2 or Firewire "Capture Now") are you limited to capturing files to the internal drive , or can you choose either internal or a Firewire external drive.
6.Powerbooks have 1-400 and 1-800 FW drive.
In a "Capture Now" scenario with files going to an external firewire drive, which device should get the 800 FW cable & which the 400 (camera or HD)?
7. Will any Superdrive record to double-sided DVD's or only recent ones?
That should do for now thanks.
Also just a general Thanks for this forum.
Can you imagine trying to figure this stuff out without you guys.
Thanks to Jared & Barry.
