[FS: General] Lanparte V-mount battery Pinch and Splitter + VB-150 battery + BMPCC cable
AlexNOR
Up for sale is my Lanparte V-mount battery Pinch and Splitter, also including a Lanparte VB-150 V-mount battery and DC Power Supply cable for the Blackmagic Pocket Camera.
I purchased this directly from Lanparte about a month ago. The unit is brand new and have never seen any real world use. It has only been mounted on different rig configurations for testing. I am now selling it because I am moving to a Canon C100 and no longer have a need for this. It is a nice solution with many outputs, built in HDMI-splitter (never tested this one), and built in battery charger. The D-Tap out is 16.4V when the battery is fully charged, and drops slightly as it drains.
There is one, in my mind, major design flaw with this product. And that is the rod mount clamp. It is very difficult to securely mount the pinch in the vertical position with the rods on the bottom. It will easily come loose once you want to take off the battery. I tried fastening it tight using some pliers, but did not have so good results with that. A solution to this I was thinking of would be to purchase a cheese plate like this one http://www.coollcd.com/cool-cheese-plate-v4-multipurpose-mounting-plate_p1093.html to replace the original rod clamp and add extra support. Note that I never got around to actually do this, but I can tell that some slight modifications are required. Another option that I've found works better is if you remove the thumb screws and rotate the rod clamp 180 degrees so the side with the logo faces towards the battery, that way the pinch has something to rest against.
Mounting it in the horizontal position resting on the rods is not a problem however.
Please note the scratches on the thumbscrews for the rod clamp. This is from when I attempted tightening the pinch securely in the vertical position using pliers. More info on that above.
What you see is what you get.
1 pc Lanparte V-mount battery Pinch and Splitter (http://www.lanparte.com/html/106.html
- Includes Power adapter, 4 pcs 12v coiled power supply cables, 1 pc 7.4v coiled power supply cable
1 pc Lanparte VB-150 V-mount Li-ion battery (http://www.lanparte.com/html/108.html)
1 pc Lanparte Blackmagic Pocket Camera DC power supply cable (http://www.lanparte.com/html/211.html)
1 pc non-branded Blackmagic Pocket Camera DC power supply cable
1 pc non-branded DC Power Jack 5.5 x 2.1mm Female to 2.5 x0.7mm Male Plug Cable plug adapter
2 pcs non-branded DC Power Jack 5.5 x 2.1mm Female to 5.5x2.5mm Male Plug Cable plug adapter
Please note: I have only used the original Lanparte DC power supply cable. I recommend checking each non-branded cable before use with a multimeter to make sure there are no polarity issues.
Total retail price from Lanparte without the non-branded cables: US$432.00 + shipping
Asking price: US$350.00 included shipping to Europe* and PayPal fee
*Standard shipping by the Norwegian Postal Service. Shipping included only if batteries can be shipped to your country using this method. Please contact me.
Item location is Norway. Paypal only for sales outside of Norway.
Please contact me for any questions and solution regarding import tax to your country.
If you have any questions please do not hesitate to post it here or contact me via pm.
Note: This listing is also posted on BMCuser.com: http://www.bmcuser.com/showthread.p...Pinch-and-Splitter-VB-150-battery-BMPCC-cable
