cowpunk52
Personally, I think this is hands down the best follow focus you can get under $1000. The only reason I'm selling is because I got a killer deal on a Chrosziel FF, and I don't need two. There is literally zero play and no slop whatsoever in this FF, and the dampening is perfect which makes it especially useful for using it with DSLR lenses. The standard gear drive (included) gives you a 1:1 gear ratio, but the extras included are a universal gear ring and another gear drive with smaller diameter that gives you about a 1:0.75 gear drive, making pulls on DSLR lenses with short focus throws far more precise. And the two hard stops are just icing on the cake!
$350 Shipped to CONUS
Here are the specs:
Compatible with most DSLR Cameras Canon EOS 5D Mark II, EOS 500D, EOS 7D; Nikon D90, D300S, etc..
Completely gear-driven design for slip-free, accurate, and repeatable focus movement
1:1 gear ratio allowing smooth movements for still and motion picture 35mm lenses
Adjustable slide-mounting mechanism to fit large range of lens diameters, including video camera lenses.
Interchangeable drive gears including 0.8 film pitch and fujinon pitch (for fujinon video lenses)
Easily switchable to either side of camera, you can easily change the gear from one side to another.
3D marking disk allow focus marks to be easily viewed by operator or assistant
Standard arri-style accessory port in focus wheel for attaching whip, speed crank, etc.
Industry-standard 15mm lightweight (60mm spacing) rod mounted
Machined with high quality, machined aircraft-grade aluminum
Lightweight design
Compatible with STANDARD 15mm rods.
Here are the specs:
Lightweight design
