[FS: General] Ki Pro Mini with mounting plate $1,550
Duke M.
SOLD
This sale includes a mounting plate (usually sold separately for $75) and an AC adapter.
(Don't be confused by others advertizing on Ebay as new when they are actually used, demos or refurbished. This unit was used in one feature film so very little use and does include the mounting plate.)
The Ki Pro Mini is a small and simple way of creating 10 bit high data rate recordings immediately usable in post, anywhere shooting takes you.
With a miniature on-camera form factor the Ki Pro Mini is powerful and supports all four types of Apple ProRes (including HQ, 422, LT and Proxy).
The Ki Pro Mini has balanced XLR inputs, SDI to HDMI and HDMI to SDI conversion, as well as up and down conversion that other recorders don't have.
The newest member of the award winning Ki Pro family, Ki Pro Mini simplifies the link between production and post by unobtrusively fitting in small spaces and acquiring on a codec better than the camera itself can use, from any SDI or HDMI camera, regardless of format. With its high quality digital connectivity, you've got the perfect solution for portable digital capture.
  • Extreme Portability for any shooting environment
  • 10-bit full raster recording to Apple ProRes 422 SD and HD formats
  • Apple ProRes 422 (HQ)
    Apple ProRes 422
    Apple ProRes (LT)
    Apple ProRes (Proxy)
  • Record Edit-Ready SD/HD files from any camera to Compact Flash (CF) cards
  • Skip log and capture with instant mounting of native OSX media
  • Professional connectivity through SD/HD SDI and HDMI I/O
AJA's Ki Pro Mini was designed as a miniature field recorder for creating "ready- to-edit" professional digital video. Ki Pro Mini supports an Apple "file-based" workflow by recording standard Apple ProRes 422 QuickTime files on industry standard Compact Flash (CF) media. When removed, Compact Flash cards function as standard HFS drives when connected to a Mac computer via any standard off-the-shelf Compact Flash reader.
Ki Pro Mini's multi-purpose mechanical design and small form factor allow flexibility in mounting to the camera or tripod using industry standard mounting plates or shoe adapters. An optional Ki Pro Mini mounting plate offers a wide variety of hole-patterns for mating either side of the unit with virtually any camera accessory bracket.
Like AJA's famous Ki Pro, KONA and Io HD desktop products, Ki Pro Mini offers unparalleled I/O quality. Within its portable and rugged form factor, Ki Pro Mini offers broadcast quality SD/HD digital I/O including SDI, HD-SDI and HDMI, two channels of balanced analog audio (2 XLRs) with switch selectable line/mic levels, and LTC timecode input.
Control options are flexible, with front panel and web browser interfaces provided (Ethernet 10/100/1000 via an RJ45 connector)."
Product Highlights
  • ProRes 422 QuickTime Files
  • Records to Standard CF Cards
  • Footage Ready to Edit in Final Cut Pro
  • 10-Bit Capture
  • Mounts to Camera or Tripod
  • HD/SD-SDI, HDMI
  • LANC, Timecode
  • XLR Audio Input
[TABLE="class: specTable, width: 0"]
[TR="bgcolor: transparent"]
[TD="class: specTopic, bgcolor: transparent"]Format[/TD]
[TD="class: specDetail, bgcolor: transparent"]Apple ProRes 422 (HQ)
Apple ProRes 422
Apple ProRes (LT)
[/TD]
[/TR]
[TD="class: specTopic, bgcolor: transparent"]Camera Compatibility[/TD]
[TD="class: specDetail, bgcolor: transparent"]Any SDI/HDMI-capable Camera[/TD]
[/TR]
[TD="class: specTopic, bgcolor: transparent"]Media Compatibility[/TD]
[TD="class: specDetail, bgcolor: transparent"]Compact Flash Cards[/TD]
[/TR]
[TD="class: specTopic, bgcolor: transparent"]Media Card Slots[/TD]
[TD="class: specDetail, bgcolor: transparent"](2) Compact Flash[/TD]
[/TR]
[TD="class: specTopic, bgcolor: transparent"]Input/Output[/TD]
[TD="class: specDetail, bgcolor: transparent"]HD/SD-SDI w/24-bit Embedded Audio: BNC (x1)
HDMI w/24-bit Embedded Audio: SMPTE-259/292/296 (x1)
Analog Line/Mic Audio: XLR 24-bit A/D (x2 Output)
Ethernet: RJ-45 (x1)
Timecode: BNC (x1 Input)
Headphones: 3.5mm Mini Jack (x1 Output)
LANC Loop (x2)
[/TD]
[/TR]
[TD="class: specTopic, bgcolor: transparent"]Power Requirements[/TD]
[TD="class: specDetail, bgcolor: transparent"]100-240VAC[/TD]
[/TR]
[TD="class: specTopic, bgcolor: transparent"]Power Consumption[/TD]
[TD="class: specDetail, bgcolor: transparent"]12VDC[/TD]
[/TR]
[TD="class: specTopic, bgcolor: transparent"]Dimensions (WxHxD)[/TD]
[TD="class: specDetail, bgcolor: transparent"]1.8 x 5.4 x 3.5" (4.6 x 13.7 x 8.9 cm)[/TD]
[/TR]
[TD="class: specTopic, bgcolor: transparent"]Weight[/TD]
[TD="class: specDetail, bgcolor: transparent"]1.26 lbs (0.57kg)
[/TD]
[/TR]
[/TABLE]
PM for fastest response if interested.
