So I am thinking about a KFlect or CRLS type system. For those who don't know it is a reflector based way of lighting that depends on a parallel beam source (less than 4 degrees with a very straight path - similar to the sun in fact).
https://www.kflect.com/home-en
http://www.christianberger.at/crls/
The issue is the light source. Ridiculously expensive.
The larger beams (like KFlect) are really reflector/bowls which cost between 4000-8000€ and additionally need an HMI light source like a Joker (costing another $4-8K).
Or you can buy the CRLS version, which only costs $21,000.
The only other alternative (nothing in between) that I see are the the very small Dedolights like the DLED9's or DLH4 which can focus down to 4 degrees. They then make an attachment to do parallel beam.
Get this, just the cone attachment to hold the grid (basically a small hollow metal tube) costs...$800.
And then you have to buy the grid seperately as well !
They really are taking the piss. It's disgraceful.
Not to mention that a single 90W light head is between $1200-$1600.
So.
What I need is to find a LED fresnel type light that can focus down to 5 degrees or less to produce a parallel beam.
Further, looking for something that can put out MORE than 400W of light (a 90W LED source equals about 400W by traditional standards).
Any suggestions ?
So.
Any suggestions ?
