[FS: General] Kessler K-Pod tripod with 100mm Hercules 2.0 tripod head and Planar PD8130 Projector
Status
Not open for further replies.
SergeSmArt
Hi! I have this two items for sale on E-bay and just would like to inform you about it!
Here the links:
1. Kessler K-Pod tripod with 100mm Hercules 2.0 tripod head+ Wheels $800 ( http://www.ebay.com/itm/121197133195?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649 )
2. Planar PD8130 DLP HD ( 1920X1080 resolution ) Projector for Home Theater $2000 ( http://www.ebay.com/itm/121197588255?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649 )
Description:
1. The Kessler K-Pod System™ is a revolutionary tripod camera system designed to support camera cranes / jibs. Industry standard 100mm bowl leveling system, which allows quick and accurate leveling of 100mm half-ball head.
Technical Specs
- Unrivaled 500 lbs maximum capacity (226 kg)
- Min height: 37" (94 cm)
- Max height: 64" (162 cm)
- Weight: 22lbs (10 kg)
It comes with Set if 3 Standard Caster dual locking Wheels
Planar PD8130 DLP ( HD 1920X1080 resolution ) Projector
The PD8130 is a relatively large DLP projector. it's 530mm X 455mm X 200mm
The case has a very elegant, piano black finish as you can see on pictures...
Have a removable hood that covers the rear input panel for a cleaner, curvy aesthetic.
The light path is completely sealed and eliminates the fear of dust getting into the optical path or light loss from the chassis.
The PD8130 features an all-glass manually operated ZOOM LENS with a relatively flexible zoom range that accommodates longer throw lengths.
Specification:
Projector type DLP projector - High Definition 1080p
Features Motion Adaptive Progressive Scan,
High-bandwidth Digital Content Protection System (HDCP),
3D digital noise reduction (DNR)
Display:
Image Brightness1000.0 ANSI lumens
Image Contrast Ratio10000:1
Throw Ratio 1.85 -2.4:1
Uniformity 90.0 %
Resolution 1920 x1080
Native Aspect Ratio Widescreen 16:9
Max Sync Rate (VxH) 85.0 Hz x 90.0 KHz
Lens:
Focus Type: Manual, Lens Aperture: F/2.5-2.71
Zoom Factor: 1.3x Lens Shift Direction
Vertical Shift 100% / 120
Video Input: Analog Video Format PAL-I, SECAM-M, M-NTSC, SECAM, PAL-N,NTSC 4.43, PAL-B/G, PAL-M, PAL-H
Expansion / Connectivity:
Interfaces 1.0 xS-video input - 19 pin HDMI Type A X 3 ( Management ),
1.0 x Composite video input - 9 pin D-Sub (DB-9),
2.0 x VGA input -Mini-phone 3.5 mm,
1.0 x SerialRS-232 - RCA,
2.0 x Audio line-in - 15 pin HD D-Sub (HD-15),
1.0 x HDMI input -RCA,
1.0 x Component video input - Mini-phone 3.5 mm,
1.0 x Remote control input - 4 pin mini-DIN
THIS PROJECTOR REQUIRE LARGE ROOM - AT LIST 25' LONG, TO GET IMAGE TO FIT LARGE SCREEN !
( Unfortunately I don't have a big room... and as you see on picture #8 - image is much smaller, that have to be, and I don't want to buy expensive SHORT THROW LENS to be able to fit it )
NOTE: IF YOU ARE ABLE TO COME TO MY PLACE IN BROOKLYN TO PICK UP PROJECTOR - YOU WILL HAVE:
1. AN OPTION TO TURN ON THE PROJECTOR AND SEE HOW GOOD IS IT FOR YOURSELF !!!
2. DECIDE AFTER YOU CHECK IT - "TO BUY OR NOT TO BUY?" BEFORE YOU PAY FOR IT!!!
3. SAVE A LOT OF MONEY on S&H + INSURANCE, and REDUCE THE RISK OF DAMAGE ON SHIPPING ( you know how our postal services "careful" with someone else package! :) )
5. ... AND (!!!) - YOU WILL BE ABLE TO TAKE HUGE, 3 METERS WIDE, DA-LITE "C" PROJECTION SCREEN WITH YOU FOR JUST A $250 EXTRA! :)
ALL YOU NEED - IS ONLY TO HAVE A CAR WITH ROOF TOP RACK ( FOR THE SCREEN ), A TIME AND ENOUGH CASH ON HAND AT PICK UP TIME!
DA-LITE MODEL C PROJECTION SCREEN 65x116 HIGH POWER 2.4 GAIN 79046
Heavy-Duty Pull-Down Projection Screen
65"x116" Viewable Size - 133" Diagonal
High Power 2.4 Gain Screen Surface - Mfg # 79046
Description
Heavy-duty pull down screen designed for years of constant use
Perfect for large classroom, meeting room or your media room.
Easy pull-down system locks at intervals to fit a variety of projection formats.
Permanently lubricated steel ball bearings combined with nylon bushings
and heavy-duty spring assembly offers smooth operation even in demanding applications.
Case design allows for hanging from a ceiling or flush mounting to a wall
Screen Surface
High Power
This screen surface provides the reflectivity and optical characteristics of a traditional glass beaded surface with the ability to clean the surface when necessary.
Its smooth textured surface provides the highest gain of all front projection screen surfaces with little loss of resolution.
The moderate viewing angle and its ability to reflect light back along the projection axis make this surface the best choice for situations
where there is a moderate amount of ambient light and the projector is placed on a table-top or in the same horizontal viewing plane as the audience.
Flame retardant and mildew resistant.
Viewing Angle: 30°
Gain: 2.8
Made in U.S.A.
Case length = 123 5/16"
Weight = 68 lbs
DaLightScreen.jpgOnShelf.jpgPlanar.jpgPlanar_2.jpgPlanar_4.jpgProjector_placement.jpgRearPanel.jpgRemoteControl.jpgScreen.jpgzoom_video37-Planar-menu2.jpg
So, please go to E-bay, if you would like to get it!!!
The best option is to COMING TO MY PLACE IN BROOKLYN, and PICK IT UP!!
Status
