Bought original kessler crane (8ft), works great, no scratches or anything. Only used twice in short production. I'm also including the soft case which I bought separately from them as well as the video clamp to attach your monitor and weights. Selling for $450. Local pickup is best, if you're outside of Atlanta then you pay shipping.
EDIT: it's also expandable to 12ft if you decide to increase it, but you'll have to buy the extra piece from them to expand. i didn't need 12ft so i never bought that.
-------------------- TECHNICAL SPECS -------------------------
* Camera capacity: Up to 25lbs. in under slung position
* (11.3kg)
* Unit weight: 20 lbs. (9kg)
* Folded length: 48 inches. (122cm)
* Extended length: 8 ft. (2.4m)
* Distance from tripod to camera: 5.5ft (1.7m)
* Total vertical movement: 11 ft. (3.3m)
* (11.3kg)
