[FS: Support] Kessler CineSlider 5ft (150cm) Length (check on Ebay)
Status
Not open for further replies.
emilian
Kessler CineSlider 5ft Length (60.5") with Removable Crank Handle (CS-1003)
This is a very sturdy and stable cinema camera slider.
You can google the Kessler brand - these guys make a professional cinema grade camera support systems in the USA.
So this is the longest 150cm (5 feet) version.
The slider has been put to a good use and I never had a problem.
Still very stable with larger cameras like the "Ursa Mini Pro" or the "Red Gemini DSMC2" + heavy cinema lens.
Of course there are normal signs of use.
Also there is a small piece missing from the crank handle, but I replaced it with something, so it is working.
This package comes with the "CineSlider Soft Case (5ft)", which normally sells for 160 EUR.
So the regular price "AS NEW" for the Slider + Case goes around 2100 EUR.
Sending to EU only, since USA will be very expensive.
Please use the listing on Ebay, or if you want to avoid Ebay, you will have to send the money and TRUST me. Its cool either way :)
https://www.ebay.de/itm/133864392825
Cheers :)
Status
