cyvideo
Obviously JVC don't want to be left out in the cold. ProRes, SSD's, 4k 50/60p 422 10-bit etc etc. Some interesting facts in here.
Both models feature a 1” 4K CMOS sensor with a 20x lens with 3-ring control (iris, focus, zoom), a high-resolution viewfinder, and a claimed 12 stops of dynamic range. Using the same codec that is found in the GY-HC900 shoulder-mount camera, the GY-HC500/ HC550 can record to SSD media in a wide variety of formats, including 10-bit ProRes 422 at 4K resolution and 50/60p frame rates. A number of other codecs and recording formats are also available, including H.264 and MPEG-2. Both cameras offer support for BT709, BT2020 and BT2100 HLG color spaces.
https://www.newsshooter.com/2018/09/11/jvc-gy-hc500-gc550/
Power draw
17.5W
Weight
3 kg
Lens
F2.8 ~ F4.5、 20x zoom
f=9.43mm ~ 188.6mm (35mm:f=28mm ~ 560mm)
Sensitivity
F11, 2000lx
Shutter
1/6 ~ 1/10000
ND
OFF, 1/4, 1/16, 1/64
Recording media
SDHC/SDXC
4K(150Mbps):UHS-I U3,4K(70Mbps)/HD (50Mbps):Class10
SD:Class4, High-Speed:UHS-I U3
SSD(M.2)、JVC SSD
Recording codecs
Apple ProRes 422, MPEG-4 AVC/H.264, MPEG-2*
4K UHD 60p/50p
(Apple ProRes 422) 3840 × 2160, Apple ProRes 422 HQ/Apple ProRes 422/Apple ProRes 422 LT, 10-bit
4K UHD 30p/25p/24p
(H.264) 3840 × 2160, 4:2:2 10-bit / 4:2:0 8-bit 150Mbps/70Mbps (MOV)
HD (H.264) 1920 × 1080/1280 × 720, 4:2:2 10-bit / 4:2:0 8-bit
50Mbps ~ 8Mbps (MOV/MP4)
HD (MPEG-2 Long GOP)* 1920 × 1080/1440 × 1080/1280 × 720, 35Mbps /25Mbps (MOV/MXF)
SD (H.264) 720 × 480/576, 8Mbps (MOV)
Proxy (H.264) 960 × 540/480 × 270, 3 ~ 1.2Mbps(MOV)
Streaming
1920 × 1080 (59.94p/50p) 20 ~ 8Mbps
1920 × 1080 (29.97p/25p) 20 ~ 3Mbps
1920 × 1080 (59.94i/50i) 20 ~ 3Mbps
1280 × 720 (59.94p/50p) 20 ~ 3Mbps
1280 × 720 (29.97p/25p) 8 ~ 1.5Mbps
720 × 480 (59.94i), 720 x 576 (50i) 8 ~ 0.3 Mbps
640 × 360 (59.94p/50p) 3/1.5Mbps
640 × 360 (29.97p/25p) 3 ~ 0.3Mbps
Connections
3G-SDI (BNC × 1)、HDMI × 1、AV (Φ3.5mm) XLR × 2(MIC、+48V/LINE), φ3.5mm
RCA × 1
USB(3.0)
Ethernet RJ-45 ×1
LAN 2.4GHz/5GHz MIMO
SSD
Chris Young
Power draw
17.5W
Weight
3 kg
Lens
Sensitivity
F11, 2000lx
Shutter
1/6 ~ 1/10000
ND
Recording media
SDHC/SDXC
SSD(M.2)、JVC SSD
Recording codecs
4K UHD 60p/50p
4K UHD 30p/25p/24p
Streaming
Connections
RCA × 1
USB(3.0)
Ethernet RJ-45 ×1
SSD
Chris Young
