Gary Senda
but some of the more recent clips I have seen look much better - possibly due to better understanding of the camera's settings by the operators.
You are absolutely right. For example, there's a color picker to shift the white balance, both in AWB and auto: no one has tried it, yet. The shifter could be useful: every time you perform a new white balance you preserve the shifting. There is a wide dynamic range (WDR) setting: I have never tried it and I have not seen any clip with this setting. If you have a scene with a lot of dark areas you can lower the gamma value to get a better discrimination, but highlights go worst. On the other side, if you have a lot of highlights you can increase the gamma valulue, but dark areas go worst: never tried. All the clips you see is by people that, like me, have shooted mainly with factory settings to test the camera and the lack of scene files doesn't help. Probably, in the next months, we will see a lot of suggested settings on the web.
Anyway, this is a frame with factory settings (I've posted it in another thread, also). The lens is an excellent zuiko 14-35mm f2 and VSM is 86% (so the sensor is remapped, larger than in m43 because the lens produces a bigger circle than others m43 lenses)
https://www.dropbox.com/s/evahlifkdyh78f7/vlcsnap-2015-05-17-11h04m27s200.png?dl=0
Even in factory settings this is not a video look, in my opinion. Rather it is a digital photo look.
Another thing: when you mount a lens that produces a smaller circle than S35 you can decide the right remapping with an utility: you can measure the light in the center and in the angles, so you can be sure that there isn't any vignetting. VSM for m43 lenses normally is 80%, but some lenses have a bigger circle and perform well with 86% and with this VSM value there is not any oversampling
To rent the camera is a good idea: I've bought it after I've tried for 2 days
Regards
Gary
