Bought new from B&H a few months ago. ($3,400)
Camera is in like new condition.
Used on one project. Excellent quality.
Original box. Extra battery and one 16g SD card
Bokertonepictures@yahoo.com
The JVC Pro HDGY-HM100U ProHD Camera is a revolutionary product which incorporates many aspects of major broadcast camcorders packaged into a lightweight, handheld camcorder. Modesty ends there however, as the camera's capabilities far exceed models in its class. With the ability to shoot high definition footage up to 35 Mbps, the camera ushers in a new level of quality, eliminating many problems associated with other methods.
At its core, the GY-HM100U HD builds on the success of JVC's previous tape-based ProHD cameras, instead recording footage to SDHC cards. Solid-state recording increases workflow speeds; shoot and start editing in minutes! Additional features include a sophisticated focus assist, uncompressed audio capability, optical image stabilization, and 2 hot-swappable SDHC slots. All these things make the GY-HM100U HD an ideal ultra-compact video camera for enthusiasts and professionals.
• Compact Frame
The camera's compact frame makes it easy to venture into uncharted territory. Long gone are the days of lugging around a brick one hand. The GY-HM100U's lightweight body allows for long run times without the fatigue. Whether you're shooting a documentary, wedding, or grabbing the news, both your wrists and your arms will thank you.
• Sophisticated Format
JVC's proprietary HD format is based on industry standard MPEG-2 compression, used for both HD broadcasts and DVD videos. By using the same basic technology as HDV and incorporating some advanced industry know-how, the GY-HM100U can shoot 720 at 19Mbps and 1080 at 25Mbps. The major difference, however, is the ability to shoot both resolutions at 35Mbps, producing the highest quality MPEG-2 video available! The format can be recorded in .mov form, making it easy to ingest into Final Cut Pro for quick direct-to-edit flexibility. For PC users, video can be recorded as ISO Base Media, which is compatible with virtually all major Non-Linear editors.
• Recording to SDHC
Unlike other cameras that record to expensive proprietary memory cards, the GY-HM100U shoots to the abundant SDHC standard. Recording hours of high definition footage across two slots; both are hot-swappable and can be quickly ingested into any computer or device with any inexpensive SD card reader. How's that for cost-effective?
• Cutting Edge CCD Technology
The 1/4" progressive scan CCDs produce stunning images with picture perfect color accuracy. The sensors incorporate spatial offset technology, which places the red and blue sensors 1/2 of a pixel in respect to the green sensor, increasing effective resolution without sacrificing image quality or by using interpolation.
• Fujinon Lens
The camera comes equipped with a 10x HD lens developed by Fujinon, the leader in broadcast-level video optics. The lens takes advantage of a compact 3-aspheric element body, which decreases both size and weight. The lens exhibits exceptional quality while showing less distortion, color aberration, and flare. Additionally, the lens comes with a built-in lens flip-up cover so users don't have to keep track of those pesky lens caps.
• Optical Image Stabilization
The Optical Image Stabilization incorporated in the lens helps defeat camera shake from handheld shooting, as well as turbulence produced from a moving vehicle. Since it's an optical function, OIS can compensate for a greater amount of problems while avoiding any loss in image quality, which is common when using more antiquated electronic or digital stabilizing methods.
• High Quality Digital Signal Processor
The camera's digital signal processor encodes all formats from a pristine 1920 x 1080 signal, ensuring all footage is of the highest resolution and quality. By starting with the maximum amount of color and spatial information the recorded footage will prove crystal clear every time. Additionally, JVC has incorporated a series of noise reducing technologies that take the entire process to another level.
• Professional Audio Capability
Just because the camera is small doesn't mean its audio capabilities are. The GY-HM100U has audio control and capability almost exclusively found on ENG camcorders! Located just in front of the handle are 2 standard XLR inputs with phantom power. Unlike its MPEG-2 HDV counterpart, JVC has upped the ante by electing to use LPCM (Linear Pulse Code Modulated) uncompressed 16-bit audio, taking productions to that coveted 'next level'. To ensure you get the most out of their sound system, JVC has provided a high-quality shotgun microphone to accompany the already sublime internal bi-directional microphone.
• Focus Assist
Taking its cue from JVC's ProHD line of camcorders, the GY-HM100U uses an edge-detection technique for image focus-assist. With the increasing importance to verify one's focus on lower resolution LCDs, focus-assist has become incredibly important. Unfortunately, it can be tricky at times. Some methods even obstruct the view of a frame, which can be both tedious and useless. The best part of the GY-HM100U's method is that it doesn't hinder the operator's ability to frame a shot or follow the action, which in the end, is most important.
• LoLux Mode
JVC's exclusive technology allows users to shoot in extremely low lighting conditions. Whether you're making that next great reality show or simply need to grab something in a dark room, LoLux mode has it covered.
• Compact Frame
• Recording to SDHC
• Fujinon Lens
• Focus Assist
• LoLux Mode
