JVC GY-HM790U ProHD Solid State Camcorder w/ Canon 14x4.4mm Lens - $7995
This is a demo model/b-stock camera. Has an awesome Canon ENG 14x4.4mm lens with servo controls. Perfect for ENG/run-and-gun. Records onto SD cards.
Up to 1080i60. Sharp, clean images. Only 155 hours on it. Comes with Anton-Bauer Gold-mount plate but can be swapped for IDX V-mount or adapted.
Comes with original box, docs, and mic.
PM or cal 512-440-1400 for details. Ships Free UPS Ground, US only.
Patented 3-CCD optical system provides full HD resolution images
4:2:2 processing
Built-in Genlock
1080i / 720p / 480i multiscan
Industry standard bayonet lens mount
HDSDI output
Patented Focus Assist function
Extensive image customization modes (gamma, matrix, knee, detail, etc.)
Compact Shoulder form factor
Records to dual hot swappable SDHC memory cards
Professional recording with selectable data rates up to 35Mbps: 1920 x 1080 (1080p24/p25/p30, 1080i60/i50), 1280 x 720P (p60/p50/p30/p25/p24)
SD recording capability (DV data format)
Native file recordingworld's fastest shoot-to-edit workflow: Native Final Cut Pro format (Edit immediately without conversion or transcoding), .MP4 file format (Compatible with most popular editing systems)
Pool feed input (analog SD)
Time code IN/OUT
High resolution (1.22 million pixel) Liquid Crystal on Silicon (LCOS) viewfinder
Large (4.3-inch) flip-out LCD monitor
Pre Rec (retro cache up to 20 seconds) function prevents "missed shots"
Variable frame rate recording (over crank, under crank)
Built-in clip viewer and management system
Uncompressed LPCM audio (2ch) recording: Manual level controls with audio meter, XLR inputs with phantom power Optional ASI output module
4:2:2 processing
Built-in Genlock
HDSDI output
Time code IN/OUT
