SOLD JVC Fujinon HZ-CA13U PL Mount Adapter for 1/3" Cameras $995
Status
Not open for further replies.
delete
delete
We have the JVC Fujinon HZ-CA13U available $995 each
These were purchased direct from JVC as B-Stock, but appear to be new and unused.
$995 with Free UPS Ground Shipping
http://shop.texasmediasystems.com/JVC-HZ-CA13U-ProHD-PL-Film-Lens-Adapter-BSTOCK-_p_113.html
The HZ-CA13U ProHD PL film lens adapter with a true optical relay system: a tool specifically designed for Digital Cinematography applications.
The design concept of the HZ-CA13U Cine Optical PL Adapter is a result of years of research consulting with filmmakers in identifying the main component most essential to digital cinematography, which has been universally identified as the film lens. To enable the use of film lenses with the ProHD line of camcorders, JVC optical engineers have implemented an all-optical relay system that takes the image from the lens and converts it to the proper proportion of the camcorder imager, preserving the depth of field (DoF) and field of view characteristics. The result is an optical tool that enables the use of 16mm, Super16 and 35mm film lenses with a PL mount with the JVC ProHD series of camcorders.
HZ-CA13U Specifications:
Conversion Ratio: x0.47
Aperture: f/1.4
Size Length: 138.2 mm (Mount to Mount)
Diameter: 78 mm
Weight: 860 g
Mount for Lens Side: PL Mount
Mount for Camera Side: 1/3-inch Bayonet Mount
Status
