Erik Naso
JVC DT-V24L1 24" 1080P Broadcast Monitor is in perfect condition.
Never been used in the field. Has been my main broadcast grading monitor in a smoke free environment. Check out the PDF for all the specifications. Note that this model doesn't have SDI. All other specifications are the same. Also works great as a computer screen. I used it both ways but primarily as a grading monitor since it can be calibrated easily. To connect it to a AJA card a HDMI cable that has a DVI-D on the other end is ideal. Basically any video card can be used too as long as an adapter is used. The monitor is built like a tank. It weighs in a t 36 pounds.
$700 plus shipping CONUS. Actually shipping prices will be added once buyer supplies address. Since the price varies. Paypal gift payment preferred.
Owners manual. http://pro.jvc.com/pro/attributes/monitor/manual/DT-V24-20L1D.pdf
[TH="colspan: 2"]Shipping Info[/TH]
| Video System | NTSC, PAL, SECAM, BW, 50/60 Hz |
| Application | Field, Rack-Mount, Studio Monitoring |
| Display Size | 24" |
| Maximum Resolution | 1920 x 1080(Video) 1920 x 1200 (Computer) |
| Viewing Angle | 176° |
| Color Temperature Pre-Sets | 6500k, 9300k |
| Input and Output Connectors | Composite Video: BNC (x2 Input, x2 Output) Component Video: BNCx3 (x2 Input, x2 Output) DVI: DVI-D with HDCP Ext. Sync: BNC Audio L/R: RCA Audio Assign (Monitor Out): RCA RS-485: RJ-45 8-Pin (x1 Input, x1 Output) RS-232C: 9-Pin, D-Sub |
| Power Requirements | 120/220-240 VAC, 50/60 Hz |
| Power Consumption | 1.15A |
| Dimensions (WxHxD) | 22.3 x 16.1 x 4" (56.4 x 40.8 x 9.9 cm) |
| Weight | Without Stand 19.1 lb (8.7 kg) With Stand 25.5 lb (11.6 kg) |
| Shipping Weight | 30.6 lb |
| Box Dimensions (WxHxD) | 0.0 x 0.0 x 0.0 |
