SOLD JVC DT-V24G11Z 24-Inch 3G HD-SDI Waveform Vectorscope CC Studio Monitor $3495
Status
Not open for further replies.
delete
delete
JVC DT-V24G11Z 24-Inch 3G HDSDI/SDI Studio Monitor
B-Stock with New JVC Warranty: One Year
Tested, Inspected, Excellent Condition
$3495
JVC's industry's leading Vérité Series professional monitors are widely used throughout broadcast network facilities because of their unsurpassed image reproduction and rock solid reliability. The new DT-V24G11Z is the latest studio monitor surpassing its predecessors in terms of overall picture quality and accuracy. This new "Vérité G-Series" monitor has a full 1080p image display that offers much wider color gamut and wider viewing angles than previous models. The waveform monitor is now much larger and a vectorscope has been added. A 3G/Dual-link HD-SDI input enables monitoring of 1080/60p signals. Digital closed captioning is now standard. Superior scaling and de-interlacing, 10-bit 4:4:4 1080p processing combined with traditional rotary image controls, area markers, blue check and timecode display make the DT-V24G11Z the best choice monitor for television studios, remote production vans, production and post facilities, and other demanding professional applications
The DT-V24G11Z 24-inch video monitor features 1920 x 1080 resolution, making it a true native HD monitor. As the flagship of JVC's line of HD production monitors, the DT-V24G11Z can reproduce native 1080i / 1080p/psf and 720p video images in their original form with no loss of quality due to scaling.
The DT-V24G11Z includes 3G/Dual Link HD/SD SDI inputs and is capable of displaying up to 1920 x 1080 60p uncompressed digital video sources at up to 3 gigibits per second. Looping component Y-Pb-Pr input/outputs are provided along with two composite video input/outputs. High definition signals can also be displayed through a DVI input with HDCP. HDMI signals can also be used with an inexpensive cable converter (not provided.) The monitor accepts external sync signals. To assure maximum quality at all time and to prevent corrosion and signal loss, the all BNC video and sync connectors are gold-plated.
DT-V24G11Z Features:
3G / Dual-Link ready for monitoring of 60 frames/2.97Gbit per second uncompressed 1080p digital video input signals: SMPTE 424M/425M/372M.
A new native 1920 x 1200 LCD Panel offers wide viewing angle of 178°/178° with minimal color change from different viewing angles. Panel provides 1:1 monitoring of 1920 x 1080 signals while providing metering and status above or below the active picture area.
Ultra High Resolution Waveform Monitor with adjustable over-level indicator function.
High quality Vectorscope allows checking of color hue and saturation.
Digital Closed Captioning Decoder built in.
10-Bit 4:4:4 Video Processing for superior image gradation, advanced directional interpolation in eliminating edge artifacts, and pixel-based motion adaptive de-interlacing.
Ultra-Low Latency Circuitry (< 1 frame) for lip-sync accuracy.
Twelve Channel Embedded Audio Metering Display with Peak Hold viewable above or below active picture area.
HD/SD SDI Embedded Time Code On-Screen Display Ergonomic Front-Panel Precision Rotary Controls.
1080/24psf Signal Capability
Full Screen Mode for SD 4:3 signals
Great deal. We ship UPS ground, signature required, double boxed and "fragile" up arrows on all box sides. We have other monitors available as well, just call us.
Status
