SOLD JVC DT-V1910CGU Professional 19" Widescreen HD CRT Monitor - MINT, low hours
Status
Not open for further replies.
bogpetri
Hi!
I have for sale a mint JVC DT-V1910CGU Professional 19" Widescreen HD CRT Monitor.
Low hours on the meter (around 200)! The screen is in perfect condition, not a scratch or a spot on the CRT glass. Plastic front looks great, no scratches, no chips. A few normal marks on the metal case. GREAT OVERALL CONDITION!
Full specs here (including a downloadable pdf file):
http://www.jvc.com.hk/media/385521/dt-v1910cgev1710cge.pdf
It can take all flavors of HD, including 720p and 1080psf so you can use it to edit and color correct all HD footage, originating from RED ONE, RED EPIC, SCARLET, and other cameras of course. Calibrated to REC 709 for professional color correction.
The regular price for a new one was $3,879. See links below for reference:
http://intl.feedfury.com/content/48977874-jvc-dt-v1910cg-19-hdtv-monitor-hi-res-hd-monitor.html
This monitor normally comes with no input cards, so if you want to use it, you need one of the several input cards made for this monitor, which are very hard to get and very expensive. The good news is, I am adding two input cards! The IF-C12HSDG HD-SDI Board for high-definition (priced at $4,125) and the IF-C01COMG for component (which can also handle high definition, but also SD) (priced at $288). See the official link below, including specs and price:
http://pro.jvc.com/prof/attributes/accessories.jsp?model_id=MDL101396&feature_id=05
These cards allow the input of basically every SD and HD format (allows for 24p and 24psf frames 720 and 24psf 1080 HD, and all flavors of SD), and I am including both of them in the purchase. You are covered for every format possible on a CRT HD screen, for your editing or your color correction sessions.
I am asking for only $1,499 for the entire package, plus shipping (PRICE REDUCED). Total value new would be $8,576 so you are getting a great discount!
Again, the monitor is in AMAZING CONDITION. By the way, the monitor comes with a very neat 16:9 bezel (mask) which you can put in front of the glass to monitor elegantly in the 16:9 aspect ratio. An additional $184 value, also brand new.
Remember, the HD input card and the component cars are damn near impossible to find.
Let me know if you're interested. Available to be picked up in Manhattan as well.
eastco@gmail.com
Thanks!
Status
